Webcast-Catalyst9k
V.110 dialin connection-speed with GSM/HSCSD
I'm using a Cisco 3640 with Mica modems (tested Portwares 2.7.2.0/2.7.4.0/2.9.4.0) for dial-in to mobile users over GSM/HSCSD. When dialing from the GSM to the Cisco router, I am able to connect only at speed 9600/9600 bps. Connection requests with higher speeds result in error: "Disconnect Reason (0x6210) - EC no fallback protocol available". I am using SonyEricsson T310 mobile.
Can you help me?
Thank's.
1 REPLY
Silver
Re: V.110 dialin connection-speed with GSM/HSCSD
It seems the 3640 and AS 5200 does not support GSM/HSCSD and the lowest platform which supports GSM/HSCSD is AS5350. You can find that inforamtion in
http://www.cisco.com/warp/public/471/terminate_v120_nextport.html
Also try the below modemcap entryt
modemcap edit new misc &F&D2S34=18000S40=10S54=172
line 1 120 ----num of modems u have
modem autoconfigure type new
Also check the following link
http://www.cisco.com/en/US/tech/tk801/tk36/technologies_configuration_example09186a0080094556.shtml
126
