04-09-2003 02:03 AM - edited 03-02-2019 06:31 AM
Hello all
If I am not wrong, the only IP-Plus IOSs that support v.92 on 3640 are 12.2.11-YT2 & 12.2.15T. Both require 96MB RAM and 32MB flash (actually I think 24MB is enough).
Is there any other IP-Plus IOS that requires 64MB RAM that support v.92?
If not is it likely that on a future major release 64MB will be enough?
Rgrds
04-09-2003 07:34 AM
v.92 on 3640 is supported on all flavours of IOS (IP, IP Plus etc) on the 12.2(11)YT2 & 12.2(15)T trains...since you are specifically looking for IP Plus, 96/32 megs are the DRAM/Flash requirement....IP requires 32/8 M.
No these is no other IP+ IOS image (that req less than 96 M DRAM) that supports v92 on the 36xx/37xx platform.
Thanks, Mak.
04-09-2003 09:58 PM
Well, the alternative version I found that I could use is the 'Telco feature set' which requires 64MB Ram.
The features we use are:
AAA / Radius Group Server
Virtual Templates / Profiles
l2tp / l2f
EIGRP
PPP / CHAP / PAP
MPPC compression
Multilink / Multichassis Multilink
ACL
SNMP
NTP
which are all supported on the Telco ios. Is there anything I should know about the Telco version, since I've never used it before?
