VC's problems
w.zhanghua
my core networks is ATM mesh
in my headquarters has 10 virtual paths, in each Virtual path we have several VC,
now i use cisco 7206 with PA-FE-TX connect to the Nortel passport 6400 ATM platform,
6400 has 10 E1 connect to the ATM MESH,
the diagram is :
LAN----(Eth)7206(PA-FE-TX)--(Eth)6400---10E1-----ATM MESH
my question is
Can i assign VCs from 7206? does the module PA-FE-TX conflict
the vc ?
maybe i need a ATM Module ,so i can assign VCs
who can tell me ?thank you in advance
beth-martin
Level 5
Level 5
Definitely will need an ATM interface in order to set up a VC.
