Verizon Point-to-Point T1 on 1605 R
Are there any tricks with these lines. I have everthing configured and the line will not come up. Verizon has claimed that the line is active but they do not see my equipment. I have plugged directly into their dmark to eliminate cable issues. The interface will not come out of inactive. I do mostly frame stuff.
Silver
Re: Verizon Point-to-Point T1 on 1605 R
Can you paste in your config frm both sides . Also you may want to find out who is providing clock
On the 1605, what card do you have ? Is it one with a inbuilt CSU or do you have an external DSU.
Give a show frame-relay pvc on the router and find out what the status of the PVCs are. (assuming that u r running frame-relay - "I do mostly frame stuff")
When you test with Verizon, first try giving a hardloop at their demarc to see if the Smart jack is working properly. If the provider is able to see the loop, then there is nothing wrong with their circuit.
I am using a T1 csu/dsu WIC on a 1605R. It is not frame which is probably why I am stuck. It is billed as a high speed DDS line. I have tried hdlc encapsulation but I have a feeling I am missing something in this area:
nterface Serial 0
no shutdown
description connected to FOXtoNA
service-module t1 clock source line
service-module t1 data-coding normal
service-module t1 remote-loopback full
service-module t1 framing esf
service-module t1 linecode b8zs
service-module t1 lbo none
service-module t1 remote-alarm-enable
ip address 172.16.6.9 255.255.255.252
encapsulation hdlc
Silver
what about the config from other side , also can you paste in sh int serial x & a sh ver from both sides.
One thing you may want to add is the serivce-module T1 fdl both command , this allows the LEC to loop your CSU .
I cannot get at the other side at the moment
sho ver
IOS (tm) 1600 Software (C1600-Y-M), Version 12.0(14), RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2000 by cisco Systems, Inc.
Compiled Tue 31-Oct-00 16:18 by linda
Image text-base: 0x02005000, data-base: 0x0245EEAC
ROM: System Bootstrap, Version 12.0(3)T, RELEASE SOFTWARE (fc1)
ROM: 1600 Software (C1600-RBOOT-R), Version 12.0(3)T, RELEASE SOFTWARE (fc1)
NAtoFOX uptime is 1 minute
System restarted by power-on
System image file is "flash:c1600-y-mz.120-14"
cisco 1605 (68360) processor (revision C) with 6144K/2048K bytes of memory.
Processor board ID 23396694, with hardware revision 00000004
Bridging software.
X.25 software, Version 3.0.0.
2 Ethernet/IEEE 802.3 interface(s)
1 Serial network interface(s)
WIC T1-DSU
System/IO memory with parity disabled
8192K bytes of DRAM onboard
System running from RAM
--More--
00:01:15: %QUICC_ETHER-1-LOSTCARR: Unit 0, lost carrier. Transceiver problem?sho int s0
Serial0 is down, line protocol is down
Hardware is QUICC Serial (with FT1 CSU/DSU WIC)
Description: connected to FOXtoNA
Internet address is 172.16.6.9/30
MTU 1500 bytes, BW 1544 Kbit, DLY 20000 usec, rely 255/255, load 1/255
Encapsulation HDLC, loopback not set, keepalive set (10 sec)
Last input never, output never, output hang never
Queueing strategy: fifo
Output queue 0/40, 0 drops; input queue 0/75, 0 drops
0 packets input, 0 bytes, 0 no buffer
Received 0 broadcasts, 0 runts, 0 giants, 0 throttles
8 input errors, 2 CRC, 3 frame, 0 overrun, 0 ignored, 3 abort
0 packets output, 0 bytes, 0 underruns
0 output errors, 0 collisions, 6 interface resets
0 carrier transitions
DCD=down DSR=up DTR=up RTS=up CTS=down
NAtoFOX#sho ver
NAtoFOX uptime is 6 minutes
Bridging software.
WIC T1-DSU
7K bytes of non-volatile configuration memory.
4096K bytes of processor board PCMCIA flash (Read/Write)
NAtoFOX#
Silver
Is this plugged in to the demac right now? If it is this is a carrier problem , you are not even receiving DCD , If not is there an extended demarc ?
If there is an extended demarc plug the router in to the demarc and see if your CD control lead is high or low , if low then it is a carrier problem
All the above control leads should be up
sorry, it is not plugged into the dmarc right now. I cannot get and internet connection and the dmark a the same time. I am working on that one. Router is on my desk. I wanted to be able to grab config info.
Silver
When you get some down time plug it in and do a sh int serial x, also if you can get the other side at this time it would be helpful
I am going to go to the remote put this back and go to the remote site now.
This is host side
NAtoFOX#sho int s0
0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
0 output errors, 0 collisions, 8 interface resets
NAtoFOX#sho running-config
Building configuration...
Current configuration:
version 12.0
service timestamps debug uptime
service timestamps log uptime
service password-encryption
hostname NAtoFOX
enable password xxxx
ip subnet-zero
no ip domain-lookup
interface Ethernet0
description connected to FastHub412
ip address 172.16.1.4 255.255.255.0
no ip directed-broadcast
interface Ethernet1
no ip address
shutdown
interface Serial0
no fair-queue
service-module t1 clock source internal
router rip
version 2
network 172.16.0.0
no auto-summary
ip classless
line con 0
transport input none
line vty 0 4
login
end
when I put the WIC into look back S0 comes right up. It has to be a telco probelm.
I will post results of lookback on remote shortly
Is the circuit a full T1 or fractional? You should have "service-module t1 timeslots 1-xx" depending on whether or not it is a full T1.
bcbv
This is a full T
366
