Webcast-Catalyst9k
Visio templates - generic network symbols
Where can I find the Visio generic network symbols template? I found the ones for each device on the Cisco Icons page but they are specific to each device.
I am documenting a network and need the symbols for IDS, SSL accel.,...
NDH
Re: Visio templates - generic network symbols
Here is the link for the Cisco Packet Icon Library MS-PowerPoint document last updated Feb 14, 2002. http://www.cisco.com/packet/network-icons You may want to copy and paste icons into Visio. You may want to then zoom in on an icon in Visio, turn on View Connection Points, select the Connection Point Tools on the toolbar and Ctrl-click to add connection points to your icon (i.e. router or switch) to have plenty of connection points to which your Connector Lines can attach.
Here is another link to the Visio Stensils with an index and multiple product families. Access will require a valid login:
http://www.cisco.com/en/US/customer/products/prod_visio_icon_list.html
2173
