Vlan 67 does not connect across 5500 for atm
mmeilan
I have 110 vlanes in a 5500 that it connects for ATM against a lightstream 1010. To this lightstream also it has connected a 7200. We have problems in one of the vlanes of 5500 (vlan 67) since from 7200 doing a show ipx server I do not see the machines of this vlan. The solution has been to connect this vlan in 5500 to 2924 and this equipment for ATM to the lightstream 1010. Someone has spent something similar or has an idea of the possible problem??? Thank you very much..
vkapoor5
Level 5
Level 5
You are saying about only single VLAN 67. With "sh ipx server" command, we can view only servers like file or print, but not all clients and depends on SAP ACL's in between the server advertisements cann't be forwarded further. So that, it cann't learned by 7200 for VLAN 67 servers. Because of this problem is only for a VLAN, check where the SAP advertisements getting blocked.
