vlan accessing problem with unmange switch
i have catalyst 3550/12gibic switch & catalyst 2950g 48 port switch how i can
configure both the switch i have given hostname,ip address,password both
for previllage & telnet i create cluster,vlan1,vlan2, is this sufficient
i can see frontpanel view
i can see topology view
i have assign ip address only vlan1
trunk port can carry multipple vlans but i have other end 3com unmanag switch i got the network but cannot ping
i need to assign manually vlan for that trunk port is that options
no switchport access vlan 2
switchport access valn 1
when i put that that connections in vlan1 it working fine
pls give me any suggession for configure the switch
1 REPLY
Re: vlan accessing problem with unmange switch
1) Use a dot1q trunk in stead of ISL with the non-cisco equipment when you want to transport multiple vlans across one link. 3Com doesn't support ISL (Cisco default/proprietary)
2) Please notice that you configure a trunk on your 3Com switch otherwise it may not work.
87
