Webcast-Catalyst9k
VLAN and LAN
i have a switch 3548.
Actually if i need to define a SPAN session, all the port related to this session has to belong to the same VLAN.
If i don't have VLAN defined, all the ports belong for default to the same VLAN?
1 REPLY
Re: VLAN and LAN
You are correct. On a non-configured switch, all ports belong to vlan1.
When using SPAN, remember that the switch will only copy the traffic flowing through the port that you are monitoring.
90
