Community Member
vlan IDs are different on links bet 2 layer 3 switches
hello,
is there any problem if the vlan IDs connecting 2 switches with multiple VLAN differs..say vlan 20 on the core and vlan 30 on the other..both of them are layer 3 and running ospf...interface connection both vlans are not trunked.
thanks.
Re: vlan IDs are different on links bet 2 layer 3 switches
it should be no problem on L3 interfaces.
I've noticed a problem with this connection while connecting L2 interfaces. Using CDP ver 2 caused error messages in my syslog (CDP v 2 sends "native VLAN" info even on access port which was different on each side).
Milan
Community Member
then what could be the reason i couldnt reach the far end switch from any of my vlan on the core except from the directly connected vlan. Intervlan is working fine. the default route specified on the msfc and the on the switch points to the vlan interface of the far end switch.OSPF is both running on both the switches. Ill attached my core config below
Router#sh run
Building configuration...
Current configuration : 646 bytes
version 12.1
service timestamps debug uptime
service timestamps log uptime
hostname Router
boot system bootflash:c6msfc2-psv-mz.121-13.E9.bin
boot bootldr bootflash:c6msfc2-boot-mz.121-13.E9.bin
clock timezone PDT -7
ip subnet-zero
interface Vlan59
ip address 10.51.20.250 255.255.255.0
interface Vlan61
ip address 10.24.50.211 255.255.240.0
router ospf 1
log-adjacency-changes
network 10.24.48.0 0.0.15.255 area 4
network 10.51.20.0 0.0.0.255 area 4
ip classless
ip route 0.0.0.0 0.0.0.0 10.24.50.201
no ip http server
line con 0
exec-timeout 0 0
line vty 0 4
login
end
Router#
Cat6506> (enable) sh run
This command shows non-default configurations only.
Use 'show config all' to show both default and non-default configurations.
begin
# ***** NON-DEFAULT CONFIGURATION *****
#time: Wed Jan 7 2004, 18:46:53
#version 7.3(1)
#system
set system name Cat6506
#vtp
set vtp domain ht
set vtp mode transparent
set vlan 1 name default type ethernet mtu 1500 said 100001 state active
set vlan 1002 name fddi-default type fddi mtu 1500 said 101002 state active
set vlan 1004 name fddinet-default type fddinet mtu 1500 said 101004 state activ
e stp ieee
set vlan 1005 name trnet-default type trbrf mtu 1500 said 101005 state active st
p ibm
set vlan 59,61
set vlan 1003 name token-ring-default type trcrf mtu 1500 said 101003 state acti
ve mode srb aremaxhop 0 stemaxhop 0 backupcrf off
#ip
set interface sc0 61 10.24.50.21/255.255.240.0 10.24.63.255
set ip route 0.0.0.0/0.0.0.0 10.24.50.201
#set boot command
set boot config-register 0x2
set boot system flash bootflash:cat6000-sup2k8.7-3-1.bin
# default port status is enable
#module 1 : 2-port 1000BaseX Supervisor
#module 2 : 2-port 1000BaseX Supervisor
#module 3 : 16-port 10/100/1000BaseT Ethernet
set vlan 61 3/1-16
#module 4 : 48-port 10/100BaseTX Ethernet
set vlan 61 4/1-48
#module 5 : 8-port 1000BaseX Ethernet
set vlan 59 5/1
set vlan 61 5/2-6
#module 6 empty
#module 15 : 1-port Multilayer Switch Feature Card
#module 16 : 1-port Multilayer Switch Feature Card
end
Cat6506> (enabl
98
