VLAN IP help.
I've setup a vlan on my switch, but I've forgotten what IP I assigned it. How can I find that out?
I have cisco IOS version 12.2(25)SED
Many Thanks
Dan
1 ACCEPTED SOLUTION
Re: VLAN IP help.
You can log into the console and find out the config.I hope you know how to do it.
Pls revert back if any prob.
JD
Re: VLAN IP help.
JD
Re: VLAN IP help.
Log on to the console and issue the following command
Show ip interface brief.
You will be able to see the IP address assigned to the particular Vlan
Narayan
250
