VLAN Issue
Hi all ,
I have a question regarding VLANS and DHCP server.
I have a Cisco 3750 as a core L3 Switch
I create the 4 VLANS ,vlan 76 ( 172.16.76.0/24) Vlan 77 , Vlan78 and Vlan 81.
I associated one port to Vlan 76, one to Vlan 77 one to vlan 78 and remainimng to Vlan 81 ( DHCP and all other servers are in VLAN 81)
On VLAN 76 vlan 77 and VLAN 78 ,i connected L2 Switch ( all ports of the switch are on same VLAn respectively)
I have set the IP helper address on each VLAN.
Now when i first cconnect the PC to VLAN 76 DHCP server issue the Correct IP to the PC( 172.16.76.X) now when i removed my PC from Vlan 76 and plugged into the Vlan 78 MY PC again get the Ip address from VLAN 76 , where as it should get IP from Vlan 78 ( 172.16 78.x)
Could you please help me in resolving the problem?
Below is the configuration of the port assosiated with VLAN 76
Interface GigabitEthernet1/0/2
description Connect-to-SegmentA
switchport access vlan 76
switchport mode access
switchport nonegotiate
interface Vlan76
description SegmentA-Vlan
ip address 172.16.76.1 255.255.255.0
Ip helper-address 172.16.81.10
172.16.81.10 is the DHCP server.
I want that DHCP should issue the ip address according to VLAN.
Looking for help
  • Other Network Infrastructure Subjects
Purple
Re: VLAN Issue
Have you created an 'interface vlan78' ? If you have, and if you have given it a 172.16 78.x address, then the DHCP server will assign it an address out of the 172.16 78.x range, providing that you have created a scope on the DHCP server for the 172.16 78.x network.
Paresh
Re: VLAN Issue
paresh
Thanks for answering
yes i have created the Interface
interface Vlan78
description SegmentC-Vlan
ip address 172.16.78.1 255.255.255.0
ip helper-address 172.16.81.10
also 172.16.78.x scope has been created in DHCP server for distribution.
Purple
Re: VLAN Issue
Can you confirm that you did a DHCP RELEASE on the PC before trying to acquire a new address when you plugged it into a VLAN 78 port ?
Paresh
Re: VLAN Issue
hI
yes I confirm you that i first release the DHCP lease by IPCONFIG/release
But reslult is same.
Attached is the Config file for core L3 switch and HP L2 2650 switches.
Please help me on this issue.
Silver
Re: VLAN Issue
Verify your DHCP scopes are defined correctly. If you defined a separate scope with separate router default gateways then your clients should allocate according to VLAN.
Re: VLAN Issue
make sure you are not using superscopes that was my issue on a problem like this.
167
