vlan on a stick using a 2621
Can I use a 2621and configure it as a router on stick. I have multiple vlans that I need to route between, but I don't know if the 2600 platform will support it. The attached switches are 2900.
Thanx
LB
Re: vlan on a stick using a 2621
If you have a fastethernet interface, you should be able to do it. Also make sure you have 2900's which are capable of trunking. The following page should answer your questions
http://www.cisco.com/warp/public/473/50.shtml
Thanx alot. That was the answer.
LB
Depending on which model of 2900 you have it may only support 802.1Q trunking. For example, I have a 2924 switch which supports ISL and 802.1Q, but I have also a 2950 and it only supports 802.1Q. Make sure the version of IOS that you have can support trunking and can also support the right type.
David.
Dave, it is a 2924. I've got the right code and I'm configuring now.
Thanx
LB
91
