01-27-2004 07:45 AM - edited 03-02-2019 01:10 PM
Hi all
I have FEDORA installed with VLAN configs
my first config is like this
internet----Eth0 (VLAN Liniux Box)eth1---- Switch port 0/1---switchport 0/2-- client
i have configured the switch port0/1 dotq and switch mode trunk
and i made the client config belong to vlan 3
in linux i have configure, eth1 3 vlan 3 and ip
and iam able to connect to VLAN and internet all coming
since i have lot of traffic, i want to loadbalance, and failover the link
i have introduced another switch between
internet----Eth0 (VLAN Liniux Box)eth1---- SwitchX port 0/1
SwitchX port 0/2----SwitchY port 0/2
SwitchX port 0/3----SwitchY port 0/3
SwitchY port 0/4--- client
i made config in cisco switch port 0/2 and 0/3 port group 1
and when i connected the switches and try to connect PC to his gateway , iam not able to ping
waht could be the problem in VLAN
any suggestion will be great
hari
01-27-2004 08:07 AM
I'm assuming this was working before you installed the second switch. If not then there are some other things that may need to be addressed. I'm also assuming, based on the etherchannel commands, that these switches are XL's.
If both assumptions are correct here are a couple of things to try.
Make sure that you have configured port groups for 0/2 and 0/3 on both switches.
Also make sure the client on SwitchY port 0/4 is configured to be in Vlan 3 and make sure that you are trunking on switchports 0/2 and 0/3 on SwitchX and switch Y.
01-27-2004 08:38 AM
Hi thanks for the quick reply
here is my config looks like
Switch X config
interface FastEthernet0/3
port group 1
switchport trunk allowed vlan 1,30-40,1002-1005
switchport mode trunk
interface FastEthernet0/4
port group 1
interface FastEthernet0/5
keepalive 10
no cdp enable
Switch Y config
interface FastEthernet0/2
port group 1
no cdp enable
port group 1
no cdp enable
no cdp enable
no cdp enable
interface FastEthernet0/6
keepalive 10
switchport access vlan 31
no cdp enable
interface FastEthernet0/7
no cdp enable
interface FastEthernet0/8
keepalive 10
switchport access vlan 30
no cdp enable
this config on real time server config
i gave the some example , so people can understand
this config , what iam running
client is connected vlan30
thanks if u can help to solve this issue
hari
02-01-2004 11:43 AM
I dont really understand your problem. It looks like you have two switches trunked together and that a client is connected to a second switch which is assigned to vlan 30. The config looks ok, but you need to check a few other things. What mode of VTP are you using (server->client)(server->server)(transparent->transparent)(etc,etc). Check the vlan database to ensure that the vlans are listed in each. Just because they are in your configuration file does not mean they are active in the vlan database. If your using VTP to propagate the vlans, ensure that you have the right vtp domain set as well as server to client or whatever. Where is your gateway come into play and what is it? A cisco router? You must also trunk the switchport to the router and set the router up with dot1q or isl encapsulated sub-interfaces, or use seperate physical interfaces plugged into access mode switchports (static vlan). Could you post a diagram of your config (attachment)?
