Webcast-Catalyst9k
VLAN Problem
I’m having a problem getting VLANs set up between my 3640 and my DLINK DES-3226L .
We have 5 ISPs and a /30 between them then a /24 or /27 of additional IP space which our NAT box (FreeBSD server) takes and NATs out to our internal servers.
The only sub interface that works is F1/0.1 and that is because I have native set on it. If I remove it and put it on another interface it works fine. Is my router configuration OK and it’s a dlink problem or is my router config not correct?
interface FastEthernet0/0
description Yipes 10Mbps Connection
ip address 66.xx.xxx.2 255.255.255.252
no ip proxy-arp
ip nat outside
ip virtual-reassembly
ip route-cache flow
speed 100
full-duplex
no cdp enable
interface FastEthernet0/1
description 10Mbps Connection
ip address 64.xxx.xxx.166 255.255.255.252
no ip proxy-arp
ip nat outside
ip route-cache flow
speed 10
full-duplex
no cdp enable
interface FastEthernet1/0
no ip address
no ip proxy-arp
ip nat inside
speed 100
full-duplex
dot1q tunneling ethertype 0x9100
no cdp enable
interface FastEthernet1/0.1
encapsulation dot1Q 2 native
ip address 192.168.101.1 255.255.255.0
ip nat inside
interface FastEthernet1/0.2
encapsulation dot1Q 3
ip address 64.xxx.xxx.1 255.255.255.224
no ip proxy-arp
no cdp enable
interface FastEthernet1/0.3
encapsulation dot1Q 4
no ip proxy-arp
no cdp enable
interface FastEthernet1/0.4
encapsulation dot1Q 5
ip address 64.xxx.xxx.161 255.255.255.224
no ip proxy-arp
no cdp enable
interface FastEthernet1/0.5
description XO
encapsulation dot1Q 6
ip address 66.xxx.xx.1 255.255.255.0
no ip proxy-arp
no cdp enable
interface FastEthernet1/0.6
description Sprint
encapsulation dot1Q 7
ip address 63.xxx.xxx.1 255.255.255.0
no ip proxy-arp
no cdp enable
interface FastEthernet1/0.7
description TWTC
encapsulation dot1Q 8
ip address 209.xxx.xxx.1 255.255.255.0
no ip proxy-arp
no cdp enable
interface FastEthernet1/1
no ip address
no ip proxy-arp
ip nat inside
speed 100
full-duplex
no cdp enable
interface FastEthernet2/0
description Sprint 10Mbps Connection
ip address 208.xx.xxx.74 255.255.255.252
no ip proxy-arp
ip accounting output-packets
ip nat outside
ip route-cache flow
speed 10
full-duplex
no cdp enable
interface FastEthernet2/1
description TWTC 10Mbps Connection
ip address 66.xxx.xx.98 255.255.255.252
ip route-cache flow
speed 10
full-duplex
no ip http server
no ip http secure-server
ip classless
ip route 0.0.0.0 0.0.0.0 208.xx.xxx.73
Any help would be great.
Re: VLAN Problem
A couple of thoughts here. First, this entry:
no ip proxy-arp
ip nat outside
ip route-cache flow
speed 100
full-duplex
no cdp enable
Your description says 10Mbps, but your config says 100Mbps, which is right?
Further, do you have proper link negotiation set up between switches. Specifically how is link speed and duplex set on the DLINK? Generally, on Cisco switches, it is better to hard code the values if they can be properly set for a non-changing link, such as a switch to switch connection. On the other hand, non-Cisco switches may not always play well with Cisco and sometimes are more/better optimized for plug and play. You could possibly have speed and duplex mismatches on the DLINK switch. You have not posted the config, so it is hard to say.
Also, it might be useful to throw both switches into 100Mbps half duplex mode and pop a sniffer (via a 100mbps hub) in the middle of the mix and see what is happening. Capture the frames and see if the two are playing nicely with each other. Good luck,
pw
Hall of Fame Super Gold
Re: VLAN Problem
Ryan
First I would like to verify my understanding of part of what you said. I think that if you configure FastEthernet1/0.1 as native that it communicates ok with the DLINK. And if you change and configure FastEthernet1/0.2 as native then it works ok. And I am guessing that if you configure FastEthernet1/0.3 as native that it works ok.
If my understanding is correct than I suspect that the issue is a difference between the way your 3640 works and the way the DLINK works. I took a quick look at the manual for the DLINK. I believe that it does not have the same concept that Cisco does of a trunk in which the native VLAN is untagged and all others are tagged. If I understand the manual correctly the DLINK either tags all frames being forwarded out an port or it untags all frames being forwarded out the port.
Can you veify how the DLINK is configured?
In my quick look through the manual I did not see anything obvious about how to configure the DLINK so that it would interoperate with the 3640. My guess is that you should configure the DLINK to tag all frames and should then configure one subinterface on the 3640 for a non-existant VLAN and mark it as native. That way both devices will process VLAN tags on all frames.
If I have misunderstood anything, please clarify.
Rick
Re: VLAN Problem
Thanks for the reply.
I'm waiting on Saturday Delivery for a 2924-XL-EN.
I figured the DLINK is no good so I just got a new switch.
Hopefully it works out.
139
