Vlan Racl question
Hello -
My IT department will be supporting a seperate company, but will be riding on our backbone. i am segmenting their network traffic using RACLs and placing them on their respective VLANs that I have created for them. I am creating a VPN tunnel so they can connect back to their netowrk resources at their head offcie. It just happens that the IP range for their head office, falls into class B that we are using at our location. I entered a more specific ACE for the ACL but for some reason it is hitting a deny statement as opposed to the permit statement the line above. Any reason for this?
Notice where the match statements are occuring when I attemt to ping a device destined to the other company's head office.
10 permit ip 10.50.162.0 0.0.0.255 172.20.4.0 0.0.3.255
20 deny ip 10.50.162.0 0.0.0.255 172.20.0.0 0.0.255.255 (3 matches)
30 deny ip 10.50.162.0 0.0.0.255 172.33.0.0 0.0.255.255
40 deny ip 10.50.162.0 0.0.0.255 172.34.0.0 0.0.255.255
50 deny ip 10.50.162.0 0.0.0.255 172.35.0.0 0.0.255.255
60 deny ip 10.50.162.0 0.0.0.255 172.36.0.0 0.0.255.255
70 deny ip 10.50.162.0 0.0.0.255 172.37.0.0 0.0.255.255
80 deny ip 10.50.162.0 0.0.0.255 172.38.0.0 0.0.255.255
90 deny ip 10.50.162.0 0.0.0.255 172.39.0.0 0.0.255.255
100 deny ip 10.50.162.0 0.0.0.255 172.40.0.0 0.0.255.255
110 deny ip 10.50.162.0 0.0.0.255 172.41.0.0 0.0.255.255
120 deny ip 10.50.162.0 0.0.0.255 172.42.0.0 0.0.255.255
130 deny ip 10.50.162.0 0.0.0.255 172.90.0.0 0.0.255.255
140 deny ip 10.50.162.0 0.0.0.255 10.50.100.0 0.0.3.255
150 deny ip 10.50.162.0 0.0.0.255 10.50.152.0 0.0.3.255
160 deny ip 10.50.162.0 0.0.0.255 10.50.156.0 0.0.3.255
170 deny ip 10.50.162.0 0.0.0.255 192.168.6.0 0.0.0.255
180 deny ip 10.50.162.0 0.0.0.255 192.168.1.0 0.0.0.255
190 deny ip 10.50.162.0 0.0.0.255 192.168.2.0 0.0.0.255
200 deny ip 10.50.162.0 0.0.0.255 192.168.3.0 0.0.0.255
210 deny ip 10.50.162.0 0.0.0.255 10.50.64.0 0.0.0.255
220 deny ip 10.50.162.0 0.0.0.255 10.49.19.0 0.0.0.255
Blue
Re: Vlan Racl question
it would be nice to have the source/destination addresses that are attempting to communicate and what protocol/port.
also, the config that shows the VACLs and how they're implemented (what vlans, etc)
Thanks for responding....
the ICMP packet matches the top ACE in the pasted RACL
Source address - 10.50.162.250
Dest address - 172.20.4.10
It is applied to the VLAN I created (in this case 162) that this traffic is originating from. I am more interested in why the ICMP packet is not hitting the first ACE on the ACL.
Blue
may sound mundane but please provide the subnet masks you have configured for hosts:
10.50.162.250
172.20.4.10
thank you.
Mask for the source host is /24
Mask for the destination host should not be an issue, since I can define ranges in ACLs anyway I choose, as long as they are valid ranges, but I am assuming they are 4 seperate /24s as well. These a the 4 remote networks, but this would be a logical assumption.
The remote network I was provided for the seperate company was .4.0 - .7.0 matching my 3.255 wildcard mask in the ACE.
Just to demonstrate that moving to 4 seperate lines in the ACL makes no difference in this problem I have included the change.
Extended IP access list RC162
10 permit ip 10.50.162.0 0.0.0.255 172.20.4.0 0.0.0.255
20 permit ip 10.50.162.0 0.0.0.255 172.20.5.0 0.0.0.255
30 permit ip 10.50.162.0 0.0.0.255 172.20.6.0 0.0.0.255
40 permit ip 10.50.162.0 0.0.0.255 172.20.7.0 0.0.0.255
50 deny ip 10.50.162.0 0.0.0.255 172.20.0.0 0.0.255.255 (3 matches)
60 deny ip 10.50.162.0 0.0.0.255 172.33.0.0 0.0.255.255
70 deny ip 10.50.162.0 0.0.0.255 172.34.0.0 0.0.255.255
80 deny ip 10.50.162.0 0.0.0.255 172.35.0.0 0.0.255.255
90 deny ip 10.50.162.0 0.0.0.255 172.36.0.0 0.0.255.255
100 deny ip 10.50.162.0 0.0.0.255 172.37.0.0 0.0.255.255
110 deny ip 10.50.162.0 0.0.0.255 172.38.0.0 0.0.255.255
120 deny ip 10.50.162.0 0.0.0.255 172.39.0.0 0.0.255.255
130 deny ip 10.50.162.0 0.0.0.255 172.40.0.0 0.0.255.255
140 deny ip 10.50.162.0 0.0.0.255 172.41.0.0 0.0.255.255
150 deny ip 10.50.162.0 0.0.0.255 172.42.0.0 0.0.255.255
160 deny ip 10.50.162.0 0.0.0.255 172.90.0.0 0.0.255.255
170 deny ip 10.50.162.0 0.0.0.255 10.50.100.0 0.0.3.255 (3 matches)
180 deny ip 10.50.162.0 0.0.0.255 10.50.152.0 0.0.3.255
190 deny ip 10.50.162.0 0.0.0.255 10.50.156.0 0.0.3.255
200 deny ip 10.50.162.0 0.0.0.255 192.168.6.0 0.0.0.255
210 deny ip 10.50.162.0 0.0.0.255 192.168.1.0 0.0.0.255
220 deny ip 10.50.162.0 0.0.0.255 192.168.2.0 0.0.0.255
230 deny ip 10.50.162.0 0.0.0.255 192.168.3.0 0.0.0.255
240 deny ip 10.50.162.0 0.0.0.255 10.50.64.0 0.0.0.255
250 deny ip 10.50.162.0 0.0.0.255 10.49.19.0 0.0.0.255
260 permit ip 10.50.162.0 0.0.0.255 any (154 matches)
Blue
Blue
looks like your first rule, 10, may not be correct.
this rule allows IP from 10.50.162.0/24 to 172.20.4.1 - 172.20.7.254.
although these ranges do seem correct as they are written, try to change the first rule to 172.20.4.0 0.0.0.255 for a test. if the test then works, you'll probably be able to find a routing issue somewhere in your environment that causes the 172.20.40.0 0.0.3.255 to be a problem. (do you really have your 172 subnetted this way? if not, then we may have to look further at the routing)
The address scheme that you see in these ACLs are in fact the way it is designed. That was done probably 8 years ago, by an engineer, who probably wan't that expierenced (as you notice there a handful of public ranges that we are using in private space). That is a project for another day though.
The routing issue you mentioned doesn't seem to be the culprit though. I can remove the deny 172.20 ACE and the packets gets routed fine to its end destination over the IPSEC tunnel.
I might end up getting rid of our 172.20 network sooner than later if I can't figure out a solution to this issue. There isn't much left on that subnet anyways, just a bunch of legacy servers, and so radius boxes.
142
