vlan reachability problems
I've setup two subinterfaces on two seperate routers. The etherchannel links connecting them to the switch are trunks w/ no restrictions. Below I've setup two virtual interfaces on the same subnet and same vlan... The layer 3 info is correct as is the vlan encapsulation type and vlan number.
RouterA
interface Port-channel1.201
encapsulation dot1Q 201
ip address 192.168.201.1 255.255.255.0
RouterB
ip address 192.168.201.2 255.255.255.0
When on each router I can ping its local 192.168.201.x address but not the far end address. No acls are in place that would prevent this. Also the arp tables on each router do _not_ show the others 192.168.201.x address - only its own....
I've tried clearing the arp table and uping/downing each interface on both routers - still no connectivity between the two.
Now I can put in a static routes on each router -like so
routerA
ip route 192.168.201.2 255.255.255.255 Port-channel1.1 192.168.0.2
routerB
ip route 192.168.201.1 255.255.255.255 Port-channel1.1 192.168.0.1
And that will give me connectivity but I'm not seeing why this is needed as subnet+vlan info is the same..
On the main sub-interface port-channel 1.1
RouterA
interface Port-channel1.1
encapsulation dot1Q 1 native
ip address 192.168.0.1 255.255.255.0
RouterB
ip address 192.168.0.2 255.255.255.0
The above works fine. I'm at a loss as to how exactly the 'native' tag effects vlans in this situation.
I feel I should have connectivity in the 192.168.201.0/24 subnet
Suggestions?
Re: vlan reachability problems
On dot1q trunks, ethernet frames belonging to native vlan are not dot1q encapsulated. So for your second config, routers don't dot1q encapsulate ethernet frames leaving po1.1 subifs. And these frames are then switched (by ethernet switch) to the receiving router subif again with no dot1q encap. So you've no physical connectivity issue but problem is about vlans ot trunking.
For the first config are you sure that vlan 201 exists on the switch and allowed on the trunks.
Ah - yes ---- the problem was on the switch. No other port was a part of vlan 201.... Once a port was part of vlan 201 things were fine..
A 'show interface trunk' on the switch showed that vlan201 wasn't active...
I'll have to do a little research on the nuances of dot1q trunking. I was under the impression that as long as trunk was enabled things were set..
Thanks for the help!
99
