Community Member
VLAN Routing over Cat 3550 Swicthes and 4006
Hi, I have 5 Cat 3550 switches all uplink to the 4006 chassis b using GBIC fiber link.
If I were to configure the VLANS across these switches, which should I use to configure as router to route among VLANs ?
Does the 3550 provides the VLAN routing function ?
If by using the 4006 for routing purposes, what module should include for it ? Currently the 4006 comes with the "supervisor Engine II Module", 6-GBIC ports module and 24-port 10/100/1000 Base-T module.
Is there any VLAN configuration sample for the above scenerio ? Please provide the URL.
How do I configure the Switch IP address for 3550 and 4006 ? This is because like for Cat 1900, we use the command "Switch(config)# ip address x.x.x.x. y.y.y. will do but I can't find the above command in Cat 3550 /4006.
Please help.
Thank you.
1 REPLY
Re: VLAN Routing over Cat 3550 Swicthes and 4006
If you have the EMI image on the 3550, it can do intervlan routing. Post the output of sh ver. I believe I answered your question on configuring the IP address in the other post of yours
http://forum.cisco.com/eforum/servlet/NetProf?page=netprof&CommCmd=MB%3Fcmd%3Ddisplay_location%26location%3D.ee8967c/0
94
