Webcast-Catalyst9k
VLAN routing problem. Please help.
Our network is rrunning 5 vlans. Recently the config was changed so that native is not running on a data vlan. Machines on one of our vlan is unable get outside of their vlan. All other vlans are working fine. This is the message that I get:
00:27:04: IP-EIGRP: Neighbor 10.8.8.1 not on common subnet for GigabitEthernet4.5
00:27:14: IP-EIGRP: Neighbor 10.8.250.1 not on common subnet for GigabitEthernet3.2
00:27:27: IP-EIGRP: Neighbor 10.8.8.1 not on common subnet for GigabitEthernet4.5
00:27:37: IP-EIGRP: Neighbor 10.8.250.1 not on common subnet for GigabitEthernet3.2
00:27:51: IP-EIGRP: Neighbor 10.8.8.1 not on common subnet for GigabitEthernet4.5
00:28:05: IP-EIGRP: Neighbor 10.8.8.1 not on common subnet for GigabitEthernet4.5
00:28:20: IP-EIGRP: Neighbor 10.8.8.1 not on common subnet for GigabitEthernet4.5
Re: VLAN routing problem. Please help.
Tou Vue
Take a look at this page on CCO and see if that matches what you are seeing. It sounds like you may have mismatched network assignments at each end of these segments.
http://www.cisco.com/warp/public/103/15.html
Hope this helps
Bill
Tou vue,
I am also having this problem!! What did you finally do to solve it.
Net yet. Let me know if you have any luck too.
Good luck,
Tou
Silver
Can you post the configurations of the router/switch? I am assuming it is a 3550?
--begin ciscomoderator note-- The following post has been edited to remove potentially confidential information. Please refrain from posting confidential information on the site to reduce security risks to your network. -- end ciscomoderator note --
No it is a 4006
--moderator edit--
Current configuration:
version 12.0
no service pad
service timestamps debug uptime
service timestamps log uptime
service password-encryption
hostname --moderator edit-- router
boot system flash bootflash:cat4232-in-mz.120-18.W5.22b.bin
enable secret 5 --moderator edit--
clock timezone EST -5
ip subnet-zero
interface Port-channel1
no ip address
no ip directed-broadcast
hold-queue 300 in
interface FastEthernet1
no ip address
shutdown
interface GigabitEthernet1
no ip address
shutdown
interface GigabitEthernet2
no ip address
shutdown
interface GigabitEthernet3
no ip address
no negotiation auto
interface GigabitEthernet3.1
encapsulation dot1Q 1
ip address 10.8.1.1 255.255.255.0
ip helper-address 10.8.16.2
no ip redirects
interface GigabitEthernet3.2
encapsulation dot1Q 2 native
ip address 10.8.8.1 255.255.255.0
no ip redirects
interface GigabitEthernet3.3
encapsulation dot1Q 3
ip address 10.8.16.1 255.255.255.0
no ip redirects
interface GigabitEthernet4
no ip address
no ip redirects
no negotiation auto
interface GigabitEthernet4.4
encapsulation dot1Q 4
ip address 10.8.24.1 255.255.248.0
ip access-group 101 in
no ip redirects
interface GigabitEthernet4.5
encapsulation dot1Q 5 native
ip address 10.8.250.1 255.255.255.0
no ip redirects
router eigrp 100
passive-interface FastEthernet1
network 10.0.0.0
ip classless
access-list 101 permit udp 10.8.24.0 0.0.7.255 any eq netbios-ns
access-list 101 permit udp 10.8.24.0 0.0.7.255 any eq netbios-dgm
access-list 101 permit tcp 10.8.24.0 0.0.7.255 host 10.189.16.7 eq www
access-list 101 permit icmp 10.8.24.0 0.0.7.255 any
access-list 101 permit ip host 10.8.24.7 any
access-list 101 permit ip host 10.8.24.6 any
access-list 101 deny ip 10.8.24.0 0.0.7.255 host 10.8.16.1
access-list 101 deny tcp 10.8.24.0 0.0.7.255 host 10.8.24.1 eq telnet
access-list 101 permit ip 10.8.24.0 0.0.7.255 host 10.8.24.1
access-list 101 permit ip 10.8.24.0 0.0.7.255 10.8.16.0 0.0.0.255
access-list 101 permit ip host 10.8.24.245 host 10.189.16.2 log
access-list 101 permit ip host 10.8.24.246 host 10.189.16.2 log
access-list 101 permit ip host 10.8.24.247 host 10.189.16.2 log
access-list 101 permit ip host 10.8.24.248 host 10.189.16.2 log
access-list 101 permit ip host 10.8.24.249 host 10.189.16.2 log
access-list 101 permit ip host 10.8.24.250 host 10.189.16.2 log
access-list 101 permit ip host 10.8.24.251 host 10.189.16.2 log
access-list 101 permit ip host 10.8.24.252 host 10.189.16.2 log
access-list 101 permit ip host 10.8.24.253 host 10.189.16.2 log
access-list 101 deny ip 10.8.24.0 0.0.7.255 10.0.0.0 0.255.255.255
access-list 101 permit ip 10.8.24.0 0.0.7.255 any
snmp-server community
snmp-server location
snmp-server host --moderator edit-- traps --moderator edit--
banner motd ^C
Authorized Access Only, All others will be prosecuted
^C
line con 0
password 7 --moderator edit--
login
transport input none
line aux 0
login
line vty 0 4
login
end
--moderator edit-- router#
3d21h: IP-EIGRP: Neighbor 10.8.250.1 not on common subnet for GigabitEthernet3.2
Silver
It seems that there are 2 potential problems with the configurations:
1. Interfaces GE4.5 and GE3.2 are both configured as native vlan members but with different ids:
which explains the error messages you are getting. In addition, this usually causes high cpu utilization because switching is done on the cpu instead of the microcode.
2. You are running an old native IOS version. As far as I know, the maturity of the native IOS is still being debated.
hth,
Mustafa
Check how summerization is being done.May wan to turn off auto-summary in eigrp . Example
router eigrp XXX
network XXXX
no auto-summary
Bronze
I am wondering if the messages have anything to do with the users not getting out of their vlan. What vlan is not working? If its not one of the two in the messages then it is probably a separate problem.
The messages indicate a loop behind the two ports, thats why the two interfaces are seeing each other. But it seems like the mystery device is not forwarding bpdus or you would think stp would block one of the ports.
I agree that the two ports (subinterfaces) are seeing each other.
Probably because they are both configured as a part of native VLAN (i.e. not-tagged).
There is probably some mistake in assigning subinterfaces to VLANs - I would guess native VLAN should be the same on both trunks - and that's why IP addresses assigned to the subinterfaces are from different IP subnets but should be from one subnet (one - native, non-tagged -VLAN is supposed to use the same IP subnet).
STP does'n block the subinterfaces because they are probably considered as router (L3) ports and don't participate in STP then.
Milan
Silver
is vlan 4 the vlan that is not working ?
under your Eigrp config use the no auto-summary command . I beleive that Eigrp is doing classful routing
No it is vlan 5 that is not working.
Silver
can you paste in a sh ip route
I called Cisco and they sent me a new SUP II to replace the old one and also configure the switch to how it was before the changes were made (ie the new vlan 800). Everything is working now. What is weird is that I thought they were going to send me the Router switch card blade but when it arrived it was the SUP II engine blade. I figure they know what they are doing so I just installed it and everything is working fine. Does anyone know why it was the SUP II and not the router blade (WS-X4232-L3) . We have 3 other 4006s and this one is the only one with problem.
Tou
132
