VLAN Routing
Do I need to configure bridge group (irb)in 4908G if I have to pass Vlan information from one switch to another switch that are connected to 4908G?
regards,
Silju
Re: VLAN Routing
You should have created some VTP domains and designate the client and the server between the switches to pass your vlan information.
Re: VLAN Routing
Thanks for your reply,
But if I configure vtp version 2 in transparent mode will it work.? Bcoz I am not sure whether we will be able to configure vtp domain in 4908G-L3.
Silju
117
