Vlan Routing
How can I route these vlans so they can talk to each other. I'm doing this on a 6509 switch with a RSFC.
I've set up vlan interfaces with IPs on the layer 3 side of the switch but cannot ping from one vlan to the other.
Vlan 200 IP-10.2.253.253/24
Vlan 300 IP-10.2.254.254/24
Re: Vlan Routing
use 'ip help ' command to forward broadcast (first hosts of two subnet ought to ping successful each other )
Re: Vlan Routing
Within the same R(M)SFC you should be able to ping each other. However please try by checking the inerface state. The common mistake is to forget to give to give "No shutdown" command for the interface Vlan.
interface Vlan200
ip address 10.2.253.253 255.255.255.0
no shutdown
interface Vlan300
ip address 10.2.254.254 255.255.255.0
no shutdown
And if you are restarting the MSFC , be sure that you saved the configuration.
-Thanks
-Mehboob
NEC-NY
Re: Vlan Routing
Let me just go through the steps and check if you missed something.
1. Configure the MSFC card by issuing the following commands:
Hostname router
interface vlan 200
no shutdown
interface vlan 300
no shutdown
router eigrp 1
network 10.0.0.0
no auto-summary
end
2. Create vlans 200 and 300 on the 6509 switch.
switch(enable) set vlan 200 name VLAN200
switch(enable) set vlan 300 name VLAN300
2. Configure the some of the 6509 port to belong to vlan 200 and some to vlan 300.
switch (enable) set port vlan 200 2/1-12
switch (enable) set port vlan 300 2/13-24
3. Attach the workstations and configure their corresponding ip address and default gateway address (i.e. 10.2.253.x for vlan 200 and def. gateway of 10.2.253.253).
4. From a client ws in vlan 200, ping the default gateway ip address. If successful, ping vlan 300 default gateway ip address. If successful, ping the ip address of the client in vlan 300.
Chris
Network Consultant
CCNP, CCDP
Getronics
Re: Vlan Routing
Cris,
great,you have put my ouststanding issue with this problem(similar to this).
your steps are spot on!
Sam
123
