VLAN Tagging problem
I am using 3 Vlans on a C3524 Switch via two bridging 1601's to connect a remote site to the CO. The vlans are 2,6 and 7. Vlans 2 and 6 are the untagged vlans, with tagging on Vlan 7.
The problem I have is users on vlan 7 can get our local intranet and connection to internet pages with no delay but users on the other two vlans get nothing.(The pages start to come in then stop). They also have trouble getting mail. I tried swapping the tagged vlan from 7 to 6 and I get the reverse result with Vlan 6 being ok and 7 failing.
Please help!!!!!!
Re: VLAN Tagging problem
i think you should set port tag if the port belong some difference vlan simultaneously;
and the tag port belong all vlans by default.
Thanks I will give it a try
111
