VLAN Trunk Port Speed
utawakevou
Level 4
Level 4
Im setting up a test on VLAN and inter-VLAN routing where I use a 2950 and a 1751 router. I have set-up 2 VLAN's from the switch and have trunk one of the port. Using a CAT 5 patch lead, I connect it to the switch trunk port and to the router fastethernet port. I did configure fastethernet0/0.1 and fastethernet0/0.2 and encapsulate it with dot1Q. So far everything are working OK.
Since it is a 10/100 connectivity, I just want to know how will the bandwidth be shared by all the 3 VLANS (VLAN 1 is my management VLAN).
thanks
mehrdad
Level 3
Level 3
there isn't any sharing
Then what is the bandwidth of one VLAN ? is it up to 100Mbps ??
yes up to 100Mbps (there is a little 802.1q overhead, four octets to each frame http://www.zyxel.com/support/supportnote/ies1000/image/8021q.gif)
Innovations in Cisco Full Stack Observability - A new webinar from Cisco
