Vlan trunkning on a 10Mb ethernet interface(cisco 2610)
I have found that you can setup dot 1Q trunking on the ethernet interface of a 2610, But i cannot find any information on this. I have got a situation where i might need to do the VLAN routing through this 2610..
can somebody give me a reference or have used it, I can imagine the ethernet might soon get overloaded if it does the routing between the vlans.
Re: Vlan trunkning on a 10Mb ethernet interface(cisco 2610)
The following page should help
http://www.cisco.com/warp/public/473/#Trunking
I have been told trunking on 10Mbps is supported in 12.2 code but I have never tested it. Before this trunking was supported only on fastethernet and gigabit ethernet
I've had a quick look, there is no reference to an Ethernet 10MB interface!
Thats why i was embarrassed today when a customer said you could do
dot iq on 10Mb interface, but I cannot find any references to it!
I've been doing this for awhile on 10 meg interfaces on 2600s.
encapsulation dot1q vlan-id [native]
* 12.0(1)T - added / introduced
* 12.1(3)T - native keyword added
The commands are in the IOS master index and have the above version numbers next to commands. I haven't come across any cisco doc mentioning *ethernet* though but it does work.
Setup like this:
interface e0/0
no ip address (or ip address of native VLAN if not using native keyword)
no sh
interface e0/0.10
ip address x.x.x.x y.y.y.y
encaps dot1q 10
interface e0/0.11
encaps dot1q 20
Ok thanks,
I was hoping to find some doco somewhere.
As a matter of interest what are you switch are you connecting to?
202
