Community Member
vlans on 2 switches
Our network's as follow :
router (2611XM) --- switch1 (2950G) ---- switch2 (2950T)
We've configured vlan 2,3 on switch1 and vlan 4,5 on switch2.
The router do intervlan routing :
IP: for vlan2
IP: for vlan3
IP: for vlan4
IP: for vlan5
on switch1, the port connected to router and switch2 are configured as trunk
on switch2, the port connected to switch1 are configured as trunk.
Users on vlan 2 and 3 can ping each other.
Users on vlan 4 / 5 can't ping /
When switch 2 is connected directly to the router, vlan 4 and 5 can ping each other.
Re: vlans on 2 switches
can you post show VTP status of both switches.
COuld be great if you post the config of all three
Community Member
Here are the output of switches (show vtp status - sh run - sh interfaces trunk ) and router
Modify the VTP domain name on SW1 and define all VLANs on it. After a short time SW2 will learn these settings (domain name also). I hope after this InterVlan routing will OK.
Please rate me if I helped.
Community Member
I don't really understand how it works.
i've changed vtp domaine name and added vlan on switch1, vlan 3 and vlan 4 could ping each other.
i've modified the pc's IP address and put it on vlan 2, it can't ping vlan 4.
could you give some url or more explanation , please ?
Community Member
If you do a "show vlan brief" do you see all vlans properly? Are they active? In order for VTP to work correctly, both switches will need to be in the same vtp domain. I recommend making one switch a server and the other a client, be sure to set the non-server switch to transparent and then to client mode within your VTP domain.
Hall of Fame Super Bronze
I suggest configuring these switches as VTP server-client. The VTP server should be the switch connected to the router since this device will forward the VLANs that are known internally. It will not forward VLANs that reside in another database.
In order to fix your problem, follow these steps:
On Switch1:
config t
vtp domain cisco
vtp mode server
vlan 2
vlan 3
vlan 4
vlan 5
On Switch 2:
config t
vtp domain cisco
vtp mode client
Wait a minute or two and then issue SH VLAN on
switch 2, you should have all VLANs from switch1.
Make sure the port connected between switches is set
to trunk and verify if it's trunking with the command
sh int trunk.
Please let us know the outcome.
Community Member
Thanks everybody.
It's working now
