VLANS with (1) 10/100 and DHCP
I have a 2610XM router with (1) 10/100. I will have (2) VLANS. Is there a way to configure both of the VLANS on the router so they can both take advantage of my DHCP server located at another site? (If I use a secondary IP address that network can't use DHCP.)
Gold
Re: VLANS with (1) 10/100 and DHCP
If your switch supports trunking, you can use 802.1q trunking on the Ethernet interface on the router. You create a subinterface for each VLAN, and those can each have helper addresses pointing to your DHCP server. In this way, you can have both VLANs use DHCP. Here is a URL with some configuration examples:
http://www.cisco.com/en/US/customer/tech/tk389/tk390/technologies_configuration_example09186a00800949fd.shtml
Thanks for the response. Ends up that I do not have the right IOS on the router to get your suggeston to work. Such is life.
Thanks for the help!
125
