Voice Vlan problems on catalyst 3524xl
I have two Catalyst 3524XL switches. One has inline power and the other has no inline power.
I've set the voice VLAN as 101 on both switches but the non powered switch does not see the 101 VLAN.
If I do : sh spanning-tree vlan 101
I get:
Spanning tree 101 is not currently active
No parameters have been configured
can anyone help??
Many Thanks
Gus
Re: Voice Vlan problems on catalyst 3524xl
Gus, Did you add the VLAN to the VLAN database in the switch? Are both of your switches part of the same V TP domain? If so, are they both servers? Looks like your second switch never had a vlan 101 configured. Let me know what you find out.
-Bo
I'm not using VLAN database. I have a site which is configured the same and it's working fine. They have all Inline powered 3524XL switches. I'm wondering if it's a problem with the non powered switch.
Would you advise using a VTP server??
Gus
Gus,
I do not understand how you are not using the VLAN database. In order for a VLAN to be configured on this switch, you must go into the valn database editor:
Command: vlan database
Command: vlan 101 name voice
Command: exit
This will only work if the switch is a VTP server or if your VTP mode is transparent.
Also, is the switch in question a member of a VTP domain? What is its role - Server or client? If he is not the server who is and how is he connected to the server?
-Bo
228
