VoIP oid for cisco2620
zhelikhov
Good afternoon.
I use a cisco 2620 voice gateway with a module NM-HDV-2E1-60. Tell me how you look at snmp for Cisco 2620 load E1. For 2811, I found oid 1.3.6.1.4.1.9.10.19.1.1.4
handoko wiyanto
Level 3
Level 3
hi andrey,
based on my understanding that oid in 2811 found in CISCO-POP-MGMT-MIB
and after searching all ios feature set for 2620, they dont have that MIB back then.
regards,
How to update the mib on the cisco ?
As per my understanding, cisco dont have the mib that you need.
But you can contact cisco to confirm this, if you cant open a tac service request, you might want to try contacting web-help@cisco.com and they will engage you to the right team.
Thank you
