Community Member
VoIP over ISDN problems
I have a lot of delay in a BRI link to a PRI. I applied QoS CQ,PQ and doesn't worked, and I have a 1600 with 11.3(11a)in a branch and a 3640 w/11.2(11)P1 in a central site. The voice quality is fine before to begin data traffic.
VIP Purple
Re: VoIP over ISDN problems
have you tried Class-Based WFQ ? I assume you have ppp multilink enabled for the BRI ? Can you post your config ?
Regards, saludos,
Georg
Community Member
Thank you Georg,
This is the config file.
version 11.3
service password-encryption
hostname R_SanVito
aaa new-model
aaa authentication login default tacacs+ local
aaa authentication enable default tacacs+ enable
aaa authorization exec tacacs+
aaa authorization commands 0 tacacs+
aaa authorization commands 15 tacacs+
aaa accounting exec start-stop tacacs+
aaa accounting commands 15 start-stop tacacs+
aaa accounting connection start-stop tacacs+
enable secret 5
enable password 7
username ingreso password 7
ip subnet-zero
isdn switch-type vn3
isdn tei-negotiation first-call
interface Loopback0
ip address 172.31.1.18 255.255.255.255
interface Ethernet0
ip address x.x.x.1 255.255.255.0
interface Serial0
no ip address
shutdown
no fair-queue
interface BRI0
description 773-0006 Red ISDN
ip address x.x.x.202 255.255.255.0
load-interval 30
dialer map ip x.x.x.1 name Cosmos broadcast 2589041
dialer map ip x.x.x.201 name Corredores broadcast 7839005
dialer map ip 15.0.0.204 name Cariari broadcast 7989007
dialer map ip 15.0.0.205 name Pococi broadcast 7109008
dialer map ip 15.0.0.102 name Chacarita broadcast 6649000
dialer load-threshold 240 either
dialer-group 1
router eigrp 1
network 15.0.0.0
network 172.31.0.0
no auto-summary
ip classless
ip route 0.0.0.0 0.0.0.0 15.0.0.1
ip tacacs source-interface Loopback0
logging buffered 4096 debugging
access-list 100 deny ip any host 255.255.255.255
access-list 100 deny eigrp any any
access-list 100 permit ip any any
dialer-list 1 protocol ip list 100
tacacs-server host 172.16.1.52
tacacs-server key
snmp-server community RW
snmp-server community RO
snmp-server contact F.Saenz
snmp-server host 10.0.0.40
line con 0
line vty 0 4
password 7
end
Community Member
I'm not sure but I thing that this configuration, don't have PPP multilink.
VIP Purple
ppp multilink is not active. You can configure it by adding the command ppp multilink in interface config mode to your bri interface. Also, set the dialer load threshold to something like 127 (which equals 50% load). If this doesn't help let me know and we can configure a voice prioritization scheme.
GP
Community Member
Thank you, Georg,
I tested configuring ppp multilink and the problem continued. Can you try to configure some scenario with voice prioritization traffic, because VoIP is running over a DDR link but with a third party equipment (external IP solution).
134
