VOIP power inline
I trying to use a voip with a phone Alcatel voip.
I've the follow problem.
When i connect the rj45 in the phone the switch don't power the phone.
MY SWITCH IS A CISCO 6500
WS-C6509 Software, Version NmpSW: 7.6(8)
System Bootstrap Version: 7.1(1)
System Boot Image File is 'bootflash:cat6000-sup2k8.7-6-8.bin'
Hardware Version: 3.0 Model: WS-C6509
PS1 Module: WS-CAC-1300W
PS2 Module: WS-CAC-1300W
Thanks for your help
FCostalunga
Re: VOIP power inline
Hi FCostalunga,
Switch does not provide the inline power to the phone it is the line card with inline power module which provides the power over ethernet.
Can you please paste the output of sh mod and confirm which module and port you are installing your ip phone and I will confirm if that line card is capable of providing the inline power or not.
For an exmple if you have line card WS-X6148A-GE-TX on you cat6k and you connect your ip phone to this you will not get any inline power but if your line card is WS-X6148A-GE-45AF it will provide the inline power if you connect your ip phone. So it all depends on the line card which you are using to connect you ip phones.
Use this link
http://www.cisco.com/univercd/cc/td/doc/product/lan/cat6000/relnotes/ol_4498.htm
and serach for inline and you will find the moduels which are capable of providing inline power.
HTH, if yes please rate the post
Ankur
i use the module 10/100 WS-X6348-RJ-45
Mod Slot Ports Module-Type Model Sub Status
1000BaseX Supervisor WS-X6K-SUP2 2GE yes ok
Multilayer Switch Feature WS-F6K-MSFC2 no ok
1000BaseX Supervisor WS-X6K-SUP2-2GE yes standby
Multilayer Switch Feature WS-F6K-MSFC2 no standby
1000BaseX Ethernet WS-X6408A-GBIC no ok
10/100BaseTX Ethernet WS-X6348-RJ-45 yes ok
MF_DT_C1AB_1> show port capabilities 5/4
Model WS-X6348-RJ-45
Port 5/4
Type 10/100BaseTX
Speed auto,10,100
Duplex half,full
Trunk encap type 802.1Q,ISL
Trunk mode on,off,desirable,auto,nonegotiate
Channel yes
Broadcast suppression percentage(0-100)
Flow control receive-(off,on),send-(off)
Security yes
Dot1x yes
Membership static,dynamic
Fast start yes
QOS scheduling rx-(1q4t),tx-(2q2t)
CoS rewrite yes
ToS rewrite DSCP
UDLD yes
Inline power auto,off
AuxiliaryVlan 1..1000,1025..4094,untagged,dot1p,none
SPAN source,destination
COPS port group 5/1-48
Link debounce timer yes
Dot1q-all-tagged yes
Jumbo frames yes
Port ASIC group
You may suffer a physical issue, I had the same with a Cisco Access Point and 3rd party InLine power.
The solution was a simple balun that changes polarity to match the other equipment. You may have the same issue connecting a Cisco switch to a non-Cisco 802.3af device. I found a reference from Cisco that depicts what I mean:
http://www.cisco.com/en/US/products/hw/wireless/ps430/prod_technical_reference09186a008039e541.html#wp35628
Look at figure1; the intended balun is described as a prestandard passive splitter. I hope that this guess will be useful for you.
Leo
152
