vpdn chap two way authentication
i have a 2500 rtr dialing through the bri into the NAS(LAC) and forwarded from there on with l2tp to the home gateway(LNS).
the bri is configured for chap and so is the vtemplate on the LNS side..(so a two way authentication). The LNS authenticates OK from the tacacs but at the 2500 site, the following message flows:
BR0:1 CHAP: O CHALLENGE id 67 len 48 from "N1gunesliBri@garanti.com.tr"
BR0:1 CHAP: I RESPONSE id 67 len 27 from "VHG-PE"
BR0:1 CHAP: Response name (VHG-PE) does not match Challenge name (AccessTest), i
gnoring
gnoring
and the a termreq is recieved finally and the connection fails..
What do you think the problem is..
1 REPLY
Anonymous
N/A
Re: vpdn chap two way authentication
The problem is that the LAC initially
challenged the 2500 (using it's own
name), and the LNS ultimately authenticates
to the 2500. The workarounds are a
few options:
- configure the same CHAP username/
password for outbound authentication on
the LAC and LNS.
- configure the LNS to renegotiate
LCP - always.
- disable outbound authentication on
the 2500.
89
