Attention: The Community will be in read-only mode on 12/14/2017 from 12:00 am pacific to 11:30 am.
During this time you will only be able to see content. Other interactions such as posting, replying to questions, or marking content as helpful will be disabled for few hours.
We apologize for the inconvenience while we perform important updates to the Community.
vpdn enable doesn't work
i can't put "vpdn enable" on my
cisco 7507 IOS ver. 12.0(10)S1
Why is it so? What are the requirements
to enable me to put that command (router, IOS, etc)
Re: vpdn enable doesn't work
the Feature Set should be IP plus , , i mean check ur IOS , it should be IP plus enabled.
I agree with selba..just make sure the when you issue "sh ver, you have "rsp-isv-mz..." for IP plus featureset or "rsp-jsv-mz...." for Enterprise featureset..Here "s" and "j" in filename represents PLUS and Enterprise featureset resp.
251
