vpn connection
Is it possible for me to replace my vpn client on my pc with some sort of configuration on my router that initiates the tunnel rather than loading the vpn client on my pc ?
  • Other Network Infrastructure Subjects
1 REPLY
Re: vpn connection
You can achieve the same using normal IPSEC configurations mentioning the necessary IKE keys and the peer ip which will be your Central office locations router ip address.
http://cisco.com/en/US/tech/tk583/tk372/technologies_configuration_example09186a0080093f86.shtml
The above mentioned link does talks about a similar scenario inline with your requirement.Do check out the same and revert back if you have any queries ..
regds
113
