vpn connection
Hi all, when setting up a vpn connection using a client and server setup, Do I just get the server to issue dhcp addresses out, and if so do I just add a route to that network from my server location, how would I do this on my router ?
  • Other Network Infrastructure Subjects
Re: vpn connection
I would recommend DHCP.
Pls tell us what is your setup and what is the configuration on both the routers.
JD
Re: vpn connection
I have not yet configured the setup, I want my cisco 1700 router to have the config on, then I connect with a vpn client to that network. i want to give out dhcp addresses to my clients, All authentication will be done on the 1700 router, can someone show me an example config ?
Re: vpn connection
I am attaching one of my running config.It is using l2tp.
Router#sh run
Building configuration...
Current configuration : 1597 bytes
version 12.3
hostname Router
boot-start-marker
boot-end-marker
username jaideep@cisco.com password 0 jaideep
username jaideep password 0 jaideep
username brij password 0 brij
no network-clock-participate slot 1
no network-clock-participate wic 0
aaa new-model
aaa authentication login default local
aaa authentication login NO_AUTHEN none
aaa authentication ppp default local
aaa session-id common
ip subnet-zero
ip cef
vpdn enable
vpdn-group 1
! Default L2TP VPDN group
! Default PPTP VPDN group
accept-dialin
protocol any
virtual-template 1
l2tp tunnel password 0 cisco
interface FastEthernet0/0
ip address 10.0.0.1 255.255.255.0
ip nat inside
duplex auto
speed auto
interface Serial0/0
no ip address
shutdown
interface FastEthernet0/1
ip address 192.168.1.211 255.255.255.0
ip nat outside
duplex auto
speed auto
interface Serial0/1
no ip address
shutdown
interface Serial1/0
no ip address
shutdown
clockrate 2000000
interface Serial1/1
no ip address
shutdown
clockrate 2000000
interface Virtual-Template1
ip unnumbered FastEthernet0/1
peer default ip address pool CISCO
ppp authentication pap chap callin
ppp multilink
ip local pool CISCO 10.0.0.10 10.0.0.20
ip nat inside source list 1 interface FastEthernet0/1 overload
ip http server
ip classless
ip route 0.0.0.0 0.0.0.0 192.168.1.1
access-list 1 permit 10.0.0.0 0.0.0.255
line con 0
line aux 0
line vty 0 4
end
Hope this helps.
Pls rate helpful posts.
JD
Router#
Router#
Router#
Re: vpn connection
thats quite a big config, can you possibly tell me what things mean on it ? also what id layer 2 tunneling ?
Re: vpn connection
Man the bigger the configuration...the better networking expert you are :D)
If you will look at the config, there are 3 major parts:
(1)AAA server auth. on router.
(2)Layer 2 VPN config.
(3)Bit change on the Virtual-interface.......
Thats it.
JD
114
