Webcast-Catalyst9k
VPN Design Help
I work for a medium sized firm. I currently have cisco router doing vpn. However, I've been given an opportunity to address the desing of this.
I'd appreciate if someone could tell me a reasonably priced vpn solution. It would be good if the solution can be integrated with say virus and adware checking along with executing a process of checks when logging in.
If I've shown any lack of understanding on my part, then I'd appreciate any corrections.
Dan
Re: VPN Design Help
What you need is a UTM (Unified Threat Management)solution which is available with Cisco in the name of Adaptive Security Appliance (ASA 5510 will do)
http://www.cisco.com/en/US/products/ps6120/prod_models_comparison.html
Hope that helps
Pls rate helpful posts.
JD
Re: VPN Design Help
Thanks for the advice. I currently have cisco pix 515 firewalls. Will this be able to replace those. Currently my pix is using four ethernet ports each with a differnt DMZ.
Dan
Re: VPN Design Help
And to make your solution "reasonably priced"....you by a PIX 515e Firewall/VPN appliance and do the virus/adware protection at PC level.... :)
JD
106
