vpn problem
Is cisco 1721 router support vpn?If it support vpn ,whitch module is to add to ?please tell me .I was very worry about it.Others I can realize it by frame-relay,is right?
Re: vpn problem
Yes, you need a "VPN Hardware Encryption Module" to be installed on 1721. It provides IPSEC DES and 3DES hardware encryption.
The following link shows you the available VPN modules and how to install a VPN module.
http://www.cisco.com/en/US/products/hw/routers/ps221/products_data_sheet09186a0080088750.html
http://www.cisco.com/en/US/products/hw/routers/ps221/products_installation_guide_chapter09186a008007e578.html
Hope you got the answer.
Cheers :-))
Naveen
mnaveen@cisco.com
Re: vpn problem
thank you very much ,I hope that I can contact with you in future.
90
