03-29-2006 04:42 AM - edited 03-03-2019 02:32 AM
Hi all, we have got an issue whereas out vpn connects to out domain for authentication !!, the problem is that when the Windows password expires and must be changed , it does not give you this option when connecting so basically it denies you connection !! is there any way of getting around this ?
thanks
03-30-2006 10:38 AM
has anyone ever had this ?
thanks
03-30-2006 10:57 AM
I am assuming you are using the Cisco vpn client for this, is this correct? Are the clients connectong to a pix or vpn concentrator as the end point? Are the clients being authenticated straight to your Windows AD or through a Cisco ACS radius server? Please give more information about how the users are connecting for a more accurate reply.
04-04-2006 12:30 AM
Hi there, yes we are using the vpn client, they connect to a pix and get authenticated straight to windows AD, Hope this helps !!
thanks
Carlos
04-06-2006 07:14 AM
can anyone help ?
04-10-2006 04:49 AM
Does anyone know a solution to this ?
thanks all
Carlos
04-10-2006 08:26 AM
Hi Carl,
I have the same problem at my work. The end-user basically has to be in the office to reset their password and can't do it via a VPN connection.
04-12-2006 04:47 AM
Does anyone hold a solution or workaround to this ?
