VPN Solution by Cisco Product
Hi, any one please suggest for the following VPN scenerio;
A HQ office with a leased line and a 2620 router installed. It has about 5 remote office (newly proposed) which are intended to use VPN dial solution in order to access the HQ corporate server.
So in term of suitable Cisco hardware and software needed for each site (HQ & each remote office),
(1) What are the necessary hardware and software needed for each site (HQ and remote office) ?
(2) What are basic requirements for the HQ office Firewall in order to support VPN access from remote offices ?
(3) Is there any configuration sample on the Cisco websites for such VPN solution.
(4) For Cisco, is any tool so that we can use it to choose the right and suitable Cisco product based on the customers ' requirement.
Please help out
1 REPLY
Bronze
Re: VPN Solution by Cisco Product
The following links has the information for VPN devices
Cisco VPN 3000 Family
http://www.cisco.com/warp/public/752/qrg/cpqrg_ch5_vpn_security.shtml#32295
Sample configs needed for VPN devices
http://www.cisco.com/pcgi-bin/Support/browse/psp_view.pl?p=Hardware:Cisco_VPN_3000_Concentrator&viewall=true
Dynamic Configuration Tool
http://www.cisco.com/appcontent/apollo/configureHomeGuest.html
Enable Configuration Guidance - Dont forget to check the check box, As it will help you in easy identifying of components
In the Product Family Type VPN 3000 and you will see all the needed hardware and software
234
