VPS - speed and duplex settings on a Catalyst
What is the correct speed and duplex settings for a VPS connecting to a Catalyst 4006 - is it 10/half , 10/full , 100/half ,100/full or auto. We installed the network and had major issues with it set to 100/full - we changed to auto and have no issues. According to Cisco best practice , all ports should be manually set and not to auto
1 ACCEPTED SOLUTION
Re: VPS - speed and duplex settings on a Catalyst
Our best practice is not to hard code
http://www.cisco.com/warp/public/473/103.html#subfirstthree
We suggest hardcoding only if the link partner has issues with auto-negotiating. Since you are not having any issues, I suggest you leave it at auto-negotiate
1 REPLY
82
