VRF and Tacacs authentication
I have an issue authenticating to a 4500 switch running VRF-lite using TACACS.
The switch IOS is 12.2(20)E.
I have multiple VRF instances configured with 1 specific one for management.
My config is:
aaa new-model
aaa authentication login default group tacacs+ local
aaa authorization exec default group tacacs+ local
aaa accounting commands 15 default stop-only group tacacs+
ip vrf Management
rd 6:1
route-target export 6:1
route-target import 6:1
interface Vlan848
description Management
ip vrf forwarding Management
ip address X
standby 105 ip X
standby 105 preempt
ip tacacs source-interface Vlan848
line vty 0 4
access-class 21 in vrf-also
password xxx
transport input ssh
I have read the Cisco article http://www.cisco.com/en/US/products/ps6350/products_configuration_guide_chapter09186a0080434619.html#wp1034865
Which refers to Per VRF Tacacs, however when trying to configure this as per the example most of the commands are not avilable to me.
Does anyone know if there are any specific TACACS commands used with VRF?
Many thanks.
Re: VRF and Tacacs authentication
Yes, but if you read the command reference you will find that the feature you are trying to use was introduced in 12.3(7)T and you are running 12.2(20)EW, so it's not yet avaialable in the code you have running.
Hope this helps.
Thanks for the reply.
I did note this and am planning to do a upgrade.
However I was wondering if this is actually what I am after or if there is some missing config.
It seemed like this should be available if the code supports VRF...
518
