Community Member
VRF not work
Hello!
We have cat3550 12.1(19)EA1a and we want to setup VRF in next scheme:
cat3550------(inside)PIX(dmz)----r2600
------------tunnel1-------
r2600 is a exit point of all tunnels and is a point of connection VRF and global routing.
There are two subnets,which we want to connect each other and connect these subnets to the rest net.
we are using two tunnels to 2600 router and VRF
that are a VRF and EIGRP parts from our config:
ip vrf MMM
rd 1016:247
interface Tunnel1
ip vrf forwarding MMM
ip unnumbered Vlan247
tunnel source Loopback0
tunnel destination 192.168.240.254
interface Vlan247
ip address 192.168.247.46 255.255.255.240
no ip redirects
router eigrp 1016
network 192.168.0.37 0.0.0.0
network 192.168.37.0 0.0.0.255
network 192.168.40.128 0.0.0.15
network 192.168.252.32 0.0.0.3
network 192.168.252.36 0.0.0.3
no auto-summary
eigrp router-id 192.168.0.37
no eigrp log-neighbor-changes
ip route 0.0.0.0 0.0.0.0 192.168.252.33
ip route 0.0.0.0 0.0.0.0 192.168.252.37 2
ip route vrf MMM 0.0.0.0 0.0.0.0 Tunnel1
ip route vrf MMM 192.168.247.48 255.255.255.248 Tunnel1
where 192.168.247.48 255.255.255.248 - another subnet in VRF
All nodes from cat3550 in vlan247 must go to inside nodes using VRF and tunnel, all others using usual routing (EIGRP).
So,we want to access mail server 192.168.7.33, which is located in inside net (not VRF), but not successfull.
As I see all packets from node in VLAN247 are go straight on to server (not via tunnel),and back packets go via PIX (because there are no subnets 192.168.247.48 255.255.255.248 and 192.168.247.32 255.255.255.240 in EIGRP routing, and PIX is a default routing point)
and I see PIX log message like this:
Deny tcp src inside:192.168.7.33/110 dst dmz:192.168.247.35/49384 by access-group "acl_inside"
(permit clause is from DMZ to INSIDE zone, not vice versa)
However when i do
telnet 192.168.7.33 110 /vrf MMM
from cat3550
it works fine!
and I see that packets go correctly via tunnel and then via PIX to server.
Accessing between subnets 192.168.247.48 255.255.255.248 and 192.168.247.32 255.255.255.240 is fine too! (why???)
I tried set
ip route vrf MMM 192.168.7.33 255.255.255.255 Tunnel1
but no effect.
What I do wrong? Why does it not work?
I hope I explain clearly.
Thanks!
1 REPLY
Community Member
Re: VRF not work
I found that VRF work correctly when and only when destination host not in global routing (EIGRP in my case). But this happen with ip of nodes within VLAN, ip address of VLAN on cisco is access correctly anytime.
Why? Does anybody knows it?
help me,please!
174
