07-31-2006 09:22 AM - edited 03-03-2019 04:18 AM
Hey All,
I'm attempting to create a trunk between a 3750 and a Cisco 2811 router (with a 16 port switching module NM-16-ESW). I'm using an etherchannel trunk between the two. I'm trying to configure VTP on the 3750 (server) and make the 2811 a client. Below is a copy of the configs and output from relevant commands. Any clue why I'm not seeing vlans on the 2811?
2811 Router Config:
interface Port-channel1
switchport mode trunk
nterface FastEthernet1/14
channel-group 1 mode on
interface FastEthernet1/15
MPLS-TEST#sh vlans
No Virtual LANs configured.
MPLS-TEST#sh vtp status
VTP Version : 2
Configuration Revision : 1
Maximum VLANs supported locally : 256
Number of existing VLANs : 6
VTP Operating Mode : Client
VTP Domain Name : VTP
VTP Pruning Mode : Disabled
VTP V2 Mode : Disabled
VTP Traps Generation : Disabled
MD5 digest : 0xE7 0x0F 0xE8 0x89 0x47 0xAE 0x7E 0x7B
Configuration last modified by <IP of 3750> at 3-1-93 00:06:05
3750 Config and Shows:
interface FastEthernet1/0/47
interface FastEthernet1/0/48
sw-upstairs#sh vtp status
VTP Version : 2
Maximum VLANs supported locally : 1005
VTP Operating Mode : Server
Configuration last modified by <IP of VLAN 1> at 3-1-93 00:06:05
Local updater ID is 134.178.220.224 on interface Vl1 (lowest numbered VLAN interface found)
sw-upstairs#sh vlan
VLAN Name Status Ports
1 default active Fa1/0/1, Fa1/0/2, Fa1/0/3
Fa1/0/4, Fa1/0/5, Fa1/0/6
Fa1/0/7, Fa1/0/8, Fa1/0/9
Fa1/0/10, Fa1/0/11, Fa1/0/12
Fa1/0/13, Fa1/0/14, Fa1/0/15
Fa1/0/16, Fa1/0/17, Fa1/0/18
Fa1/0/19, Fa1/0/20, Fa1/0/21
Fa1/0/22, Fa1/0/23, Fa1/0/24
Fa1/0/25, Fa1/0/26, Fa1/0/27
Fa1/0/28, Fa1/0/29, Fa1/0/30
Fa1/0/31, Fa1/0/32, Fa1/0/33
Fa1/0/34, Fa1/0/35, Fa1/0/36
Fa1/0/37, Fa1/0/38, Fa1/0/39
Fa1/0/40, Fa1/0/41, Fa1/0/42
Fa1/0/43, Fa1/0/44, Fa1/0/45
Fa1/0/46, Gi1/0/1, Gi1/0/2
Gi1/0/3, Gi1/0/4
5 INTERNET active
I'm baffled why these vlans aren't showing on my 2811. Any ideas?
Mike
07-31-2006 09:28 AM
Can you post the show vlan on 2811? The show vtp stat shows that the VTP is updated by the 3750 and they both have the same number of vlans - 6.
Only the vlan information will be on VTP, VTP will not assign the vlans to the ports, if that's what you are asking. Show vtp stat on 2811 looks like vtp are being exchaged between 3750 and 2811.
Please rate helpful posts.
07-31-2006 09:37 AM
I posted the sh vlans for the 2811 above but here it is again:
MPLS#sh vlans
For kicks I even tried assigning the INTERNET vlan to one of the ports on the 2811 (fa1/1), and it took the change but when I attempt to do a sh vlans on the 2811 I still get "No Virtual LANs configured." I know I need to assign the vlans to the ports, but we use VTP between our 6509s and 3750s and all the VLANs show on all the switches... even if they are not assigned to a port on that switch. Here's some more output if it provides any help:
MPLS#sh vtp counters
VTP statistics:
Summary advertisements received : 16
Subset advertisements received : 1
Request advertisements received : 0
Summary advertisements transmitted : 14
Subset advertisements transmitted : 1
Request advertisements transmitted : 50
Number of config revision errors : 0
Number of config digest errors : 0
Number of V1 summary errors : 0
VTP pruning statistics:
Trunk Join Transmitted Join Received Summary advts received from
non-pruning-capable device
Po1 0 0 0
Thanks for the input,
Mike
07-31-2006 10:38 PM
Hi!
What about the encapsulation in under the interface port-channel?ISL Or Dot1.Q?I'm not seen this!
08-01-2006 12:44 AM
Hi Mike
Try to disable the password, by using
"no vtp password" on both.
08-01-2006 02:49 AM
I hope I do not add to the confusion, but have you defined the VLAN interfaces on your 2811 ? Can you post the full config of your 2811 ?
GNT
08-01-2006 05:35 AM
Hey All,
Thanks for the input! I was actually able to solve the issue. It appears that "sh vlans" is different on an IOS router than an IOS switch. On the router it shows sub-interface ISL/dot1q trunks to a switch. This is obviously different for me as I have a switching card. In order to see VTP in action on the router and verify it was working I actually needed to view it through the VLAN database. See below:
MPLS-TEST#vlan database
MPLS-TEST(vlan)#show
VLAN ISL Id: 1
Media Type: Ethernet
VLAN 802.10 Id: 100001
State: Operational
MTU: 1500
VLAN ISL Id: 5
VLAN 802.10 Id: 100005
State: Operational
MTU: 1500
VLAN ISL Id: 10
VLAN 802.10 Id: 100010
State: Operational
MTU: 1500
VLAN ISL Id: 20
VLAN 802.10 Id: 100020
State: Operational
MTU: 1500
VLAN ISL Id: 25
VLAN 802.10 Id: 100025
State: Operational
MTU: 1500
VLAN ISL Id: 30
VLAN 802.10 Id: 100030
State: Operational
MTU: 1500
VLAN ISL Id: 250
VLAN 802.10 Id: 100250
Certainly is confusing and left me scratching my head. Thanks for the help though! I through this up on my blog too so someone in the future isn't chasing his/her tail
-Mike
