04-04-2006 11:23 PM - edited 03-03-2019 02:39 AM
Hi All,
I know this topic has been covered earlier but nobody seems to of given a definitive answer.
Almost all of the documentation I can see says that a switch in VTP Client Mode does not store any vlan info into it's NVRAM.
My testing in the lab indicates this is not the case.
Scenario:
Configure switch X as the VTP server and switch Y as the VTP client in VTP domain TEST
Connect X -> Y via a trunk
Create VLAN 2 on switch X
VLAN 2 is then automatically created on switch Y
Disconnect the trunk link between X & Y
Power cycle switch Y
Isssue "Show VLAN" on switch Y and VLAN 2 is still present.
Whilst this is comforting behaviour for myself, I don't understand why this info conflicts with all the Cisco documentation. I am reading it incorrectly ?
Ellis Dixon
04-04-2006 11:32 PM
Hi Friend,
Can you confirm the procedure you are creating the vlan?
Ankur
04-05-2006 12:16 AM
Sure,
On switch "X" I enter configuration mode and type
"Vlan 99"
This creates me Vlan 99 on Switch X, moments later this Vlan appears on Switch Y.
Ellis
04-05-2006 12:23 AM
Hi Ellis,
Can you try something this way.
Instaed of creating vlan from global config mode go to vlan database mode from enable prompt and then create a vlan on your VTP server and let it be advertised to your vtp client switch and then remove the trunk connection and reload the vtp client switch and update if the vlan information is lost or not.
Ankur
04-05-2006 01:46 AM
Hi Ankur,
I have just tested it from vlan database mode and I get the same result, the vlan remains on switch Y with no trunk connection after the power has been removed.
Ellis
04-05-2006 03:32 AM
Ellis,
I have the same issue with my 3500 switches and agree with you. The vlan.dat file is maintained in NVRAM in Client mode. However, come the exam I may be tempted to answer that it doesn't as all the Cisco literature seems to indicate the opposite.
Phil.
