VTP problems
i have two cat 4000 with sup 3 engines. Both of my servers are configured as VTP servers so that VLANS can be created on either. However,it seems that when i create a vlan on one switch it is not being propagated to the other switch.
I have tried re-booting the switches and have upgrade the IOS to 12.1(13) EW, but the issue is the same. Also if I need to re-boot the switches, is their any particular order they should be brought back up.
when I execute "sh vtp status" on both switches, i get the following output:
switch1:
VTP Version : 2
Configuration Revision : 10
Maximum VLANs supported locally : 1005
Number of existing VLANs : 10
VTP Operating Mode : Server
VTP Domain Name : infa
VTP Pruning Mode : Disabled
VTP V2 Mode : Enabled
VTP Traps Generation : Disabled
MD5 digest : 0x5C 0xDF 0x45 0xD5 0xD1 0x74 0x44 0x25
Configuration last modified by 10.33.0.2 at 5-9-03 11:10:56
Local updater ID is 10.33.0.2 on interface Vl2 (lowest numbered VLAN interface found)
Switch2:
VTP Version : 2
Configuration Revision : 0
Number of existing VLANs : 8
MD5 digest : 0x77 0x89 0xDE 0xF4 0xF5 0xCA 0xE6 0x0E
Configuration last modified by 10.33.0.3 at 1-16-03 00:49:45
Local updater ID is 10.33.0.3 on interface Vl2 (lowest numbered VLAN interface found)
1 REPLY
Re: VTP problems
check:
1) Are these two switches connected together physically?
If yes, there must be a 802.1q or ISL trunk configured connecting these two switches. Use "sh int x/y switchport" to see if trunk is running OK. Also use "sh VTP count" to check if VTP is being received on proper ports.
If not (i.e. there are some other switches between them) there must be a "trunk path" of switches (all VTP ver 2 belonging to the same VTP domain or transparent) between them.
2) If you are using VTP password it has to be identical on both switches.
Milan
190
