VTP problems
I have a big problem with VTP.
I have a VTP Server on a Catalyst 6000 and a client on a C3750 and my client doesn't learn any Vlan...
If I try to pass my client in transparent mode and then create manually the management vlan it's working.
Can anyone help me please?
Hall of Fame Super Bronze
Re: VTP problems
Please post from the CAT6000
sh vtp domain
and from CAT3750
sh vtp status
Silver
Re: VTP problems
Try to delete the vlan.dat file and then reload the switch. After that, reconfigure the VTP.
Let me know if this solves the problem,
Silver
Re: VTP problems
One more BIG THING. When you exit the vlan database configuration do not press CTRL+Z try to type exit otherwise the config changes won't be applied.
Re: VTP problems
What version of VTP?
Try to see the name and password of vtp domain on both swicthes.
Set the vtp mode to client on the cat3750.
Re: VTP problems
check for the vtp domain name and the vtp version on both the switch... try to configure same on the both switch most probebly change your 3750 configuration for same vtp domain name and version of vtp as per your 6000.
rate this post if it helps
regards
Devang
Re: VTP problems
If you using secure mode, domain and password. check to see if the password has been configured on the client.
223
