VTP Pruning between 6509 and 3550
I currently have a port-channel set up between a 6509 and a 3550. VTP runs over this channel as well. We currently have 10 vlans, however only 2 of these will need to be configured on the 3550 switch. So I would like to do some VTP prunning to keep traffic from other vlans from going over the channel/trunk. Below is the output from the running config on the 6509 port-channel and interfaces that is set up between the 3550 and 6509. For this example I am only trying to keep vlan 7 from going over the channel. However, after setting this up, we set a fast ethernet port on the 3550 for vlan 7 just to see if the prunning would work. After hooking up a pc and setting the pc to get the IP from an DHCP server, the pc got a IP address in the range for Vlan 7 and was able to go over the network just fine. I assume it shouldn't let any vlan 7 traffic accross. Appreciate any help.
interface Port-channel2
no ip address
switchport
switchport trunk encapsulation isl
switchport trunk pruning vlan 2-6,8-1001
switchport mode trunk
interface GigabitEthernet3/2
no ip address
switchport
channel-group 2 mode on
interface GigabitEthernet4/2
no ip address
switchport
1 REPLY
Re: VTP Pruning between 6509 and 3550
The 'pruning vlan' option in 'switchport trunk' sets the list of VLANs that are eligible for pruning. So in your case vlan 7 is NOT eligible for prune. You need to replace 'pruning vlan' with 'allowed vlan' which will not allow vlan 7 to send/receive on the trunk. This will permit vlans 2-6,8-1001 and deny vlan 7. BTW we call this manual pruning. VTP pruning will automatically prune back the vlan 7 traffic (except spanning tree) if no ports on the 3550 are in vlan 7.
http://www.cisco.com/univercd/cc/td/doc/product/lan/c3550/12119ea1/3550cr/cli2.htm#2423140
86
