VTP Pruning problem
Hello:
I connect a Catalyst2924 to one Catalyst6506.there are 100 Vlans on the C6506 and just 4 vlans on C2924.As you know,there is limition on 64 vlans on c2924,so I want to use VTP Pruning to permit just the four vlans used on C2924 .I have a question:when the vtp pruning is enabled,how many vlans i shall see on c2924? Thanx.
  • Other Network Infrastructure Subjects
1 REPLY
Re: VTP Pruning problem
I am not an expert in this area, but my understanding is VTP pruning just stops traffic for a VLAN being forwarded to the switch if there is nothing in that VLAN connected to the switch. You are better off just allowing the 4 VLANs you require on the trunk. For example, on a 3524:
int f0/1
switchport mode trunk
switchport trunk allowed vlan 1,2,4,8
And a 5500 switch, it would be something like:
clear port trunk 4/1 3,5-7,9-1000
OR
set port trunk 4/1 vlans-numbers
Hope this helps
112
