WAN bridge problem
two routers connected over a leased line to connect two WAN locations,I wish to bridge the two WAN locations to form one network 10.1.0.0/16 ,the serial interfaces and lines are up with no problem still I fail to have connectivity between the locations.Can some one please check the two router logs and help?
The first router configuration
Adritec-HQ#wr ter
Building configuration...
Current configuration:
version 12.0
service timestamps debug uptime
service timestamps log uptime
hostname Adritec-HQ
ip subnet-zero
no ip routing
interface Ethernet0
ip address 10.1.0.2 255.255.0.0
no ip directed-broadcast
no ip route-cache
bridge-group 1
interface Serial0
no ip address
no ip route-cache
bridge-group 1
ip classless
no ip http server
bridge 1 protocol ieee
line con 0
transport input none
line vty 0 4
end
The second router configuration
version 12.0
hostname Adritec-Sahab
ip subnet-zero
no ip routing
interface Ethernet0
ip address 10.1.0.66 255.255.0.0
no ip route-cache
bridge-group 1
interface Serial0
no ip address
no ip route-cache
bridge-group 1
ip classless
no ip http server
line con 0
line vty 0 4
end
Re: WAN bridge problem
Hello
You mast delete ip address on the Ethernet interfaces because when you have ip addresses
assigned to interface you start routing process on this interfaces, there for you must confige IRB
but in the your's situation it will be enough if you delete ip addresses.
That's not true. You can have IP addresses on bridged interfaces. In fact it is extremely useful to do this when you configure your routers as bridges because having addresses on the interfaces allows you to telnet to the router.
use the command "no ip routing" on both routers and
it will turn them into bridges.
to manage them use the same ip address on the the lan
and wan interface,but remember to use a different address for each router.
Thanks all for your suggestions .This should have been a straight forward issue but it looks like we are missing something.
I will have to look it up more . If any one has other ideas please update me .
You are right. Your router serial interface must configure with ip address instead of no ip addr. The serial intf IP should be different from ethernet but they must in the same subnet. sure work......
589
