WAN clients get disconnected randomly
chkoid
I have a remote site (site 2) connected to HQ via 256 k lease line.
HQ -> site 1 --> site 2
(3660) (3640) (2620)
Ping dropped out of sudden for a short period if ping continously.
e.g if i ping continously (ping -l) to HQ for 4 hrs, it may get about 10
consecutive timed-out out of sudden & immediately resume.
(pinging from site 2 to 1 is having the same problem)
This causes Microsoft Terminal server client gets disconnected.
note: ICMP & interesting traffics have been given high priority queue & it does not help.
What can i do to overcome it ?
thks
ovega
Hi, can you post your configurations ??
Best regards
Hi below is the config.
Note that the problem that facing is connectivity to MS terminal server
of ip 10.201.128.8 drops intermittently (regardless of with or without priority list)
ip subnet-zero
no ip finger
no ip domain-lookup
lane client flush
isdn switch-type basic-net3
isdn voice-call-failure 0
cns event-service server
interface FastEthernet0/0
ip address 10.201.192.1 255.255.252.0
speed 100
full-duplex
interface Serial0/0
bandwidth 512
backup delay 10 30
backup interface BRI0/0
ip address 192.168.201.234 255.255.255.252
no ip mroute-cache
priority-group 2
router ospf 1
log-adjacency-changes
area 0.0.0.1 stub
network 10.201.192.0 0.0.3.255 area 0.0.0.1
network 192.168.201.232 0.0.0.3 area 0.0.0.1
network 192.168.201.240 0.0.0.3 area 0.0.0.1
ip classless
ip route 0.0.0.0 0.0.0.0 192.168.201.241 200
no ip http server
access-list 120 permit icmp any any
access-list 120 permit tcp any any eq 3389
access-list 120 permit ip any host 10.201.128.8
access-list 120 permit tcp any any eq telnet
access-list 120 permit ip any host 10.201.128.4
access-list 120 permit ip host 10.201.128.4 any
priority-list 2 protocol ip high list 120
prafuljaded
Level 3
Level 3
Please check for the types of errors (CRC, input, output , drops)on the serial link on both sides while you issue a ping. If you get errors you need to check up with ur Telco.
This can happen when you have large routing tables and use distance vector protocols like rip. It can also be caused by large sap tables if you are running any IPX. Everything pauses while the updates are sent out on their periodic cycles. Run your ping tests and time the separation between sets of lost pings. See if there is a pattern as to how often it happens. Both the things I mentioned are tuneable.
