Webcast-Catalyst9k
WAN Compression Equipment
We want compression on our WAN link which is on serial Interface. We have 3640 Router at our end and the remote end router is to be purchased. I have found from the Cisco Website that for 3640, NM-COMPR Compression Network Module can be used for Compression. While at the service providers end I can use Cisco 2600 Series with AIM-COMPR2, Compression Card.The service provider is located in Singapore. Now will you please tell me the following :
Is the hardware I mentioned above suitable for Hardware Compression. How much Compression Ratio I could get .The link’s available Bandwidth is 1Mbps.
I will be very thankful to you for your guidance in this regard.
faisal@skykom.net
1 REPLY
Re: WAN Compression Equipment
The hardware solution is a great choice. You should read through this:
http://www.cisco.com/warp/public/116/wan_compression_faq.html
259
