Community Member
Wan issues with 1720 and linksys
We have two sites set up interconnected via a 1720 over s T1 link. At the main site our isp is dsl using a linksys router (nonbusiness class). When I disconnect the linksys, I cannot ping the other site. The default
Community Member
Re: Wan issues with 1720 and linksys
What routing protocols are you using? If you do SH IP ROUTE on each 1720, do you see all of your remote routes and do they have the correct next hop?
Mick.
Community Member
I figured it out, the routes were correct, but the default gateway on the network was set to only the linksys router. I just added the cisco 1720 in dhcp as a router and that fixed the problem.
136
